Approximately 2 months ago the radiator cracked and the coolant got into the auto tranny. Car has been running fine and shifted fine until lately. Also, had replaced the tranny fluid twice.
From a cold start, car is having difficult time shifting into the second or third gear. Once the car gets hot, its fine...(5-10mins range). No shifting problem at all once the car is hot.
Other members suggested that it could be the governor seal or worn housing.....
Do you recommend changing the governor seal and/or worn housing OR replace the tranny with a used one??
