hey guys sorry for another charging thread but im very short on free time to keep searching, and i need my car back up and running asap.
So the story is its a 87 325is, i have a new battery, car ran fine for 2 weeks after new bat was put in, and then my fuel pumps cut out on the highway from a corroded power wire in the harness and i kept cranking it till it drained the bat. then i jumped it and it hasnt charged since, ive got from 11 to 12 volts at all points, both wires coming from the alt, the power dist block, and the battery, i did some reading and thought it might be the voltage regulator due to the flickering lights when i hit the fan or stereo, so i replaced it with a oem unit, and it didnt do shit, my dash light does work, it lights up at key on and goes out after it fires up, and the car will run fine, except the lights flicker sometimes and then when i shut it off its deader than hell, the lights go dark after a matter of seconds. Im a broke college kid and i cant afford to replace the alt if i dont know its that for sure and im sick of jumping the fuckin thing.
any thoughts?
thanks alot
any thoughts?
thanks alot
