So I came out of the movies this afternoon with my girlfriend and got in my car. To my dismay and slight embarrassment my e30 wouldn't start. The first thing I did was check the fuses, they were all good. Next I disconnected the return fuel line on the bypass and had my girlfriend crank it over, there was a steady stream of fuel. So there is no spark. Next I disconnected a sparkplug wire and held it against the valve cover while my girlfriend cranked again, there was no spark. Then I disconnected the coil wire to the distributor and did the same. There was no spark so I'm thinking it is the coil. That was all I could do before the tow truck got there and now it's dark.
I have misplaced my bentley manual and I am not sure how to test the coil. Beyond that, what else could be bad? DME? Ignition switch? Crank position sensor? How do I test those?
Any help would be greatly appreciated. Thank you in advance.
