Bought a 92' vert at end of summer and as things got colder this winter I noticed the car would not warm up very quickly and there was little heat...(if engine temp got at all warm I would have some heat).
Did some research on this site and came up with i guess 3 things it could be...Thermostat, Heater Valve or Heater Core.
Just changed Thermostat yesterday (might as well start with the cheapest fix) and when I took it apart the old thermostat was cut apart leaving the large flange and oring (so a slightly restricted path).
I swapped out the parts and filled the coolant per forum instructions...car jacked up and heat on full blast...
Once I started the car the engine temp began to raise but I dont think the thermostat ever opened...I sat in the car when engine temp was about 1/2 and I didnt have any heat increase through the vents...I eventually shut down the car when the engine temp gauge got to about 3/4.
Any ideas.....maybe just an air bubble??? (wishful thinking)
Any help would be greatly appreciated!!!
Mike
Mike
