So I was trying to remove my steering wheel this evening, and after doing some searches I found out that there's two T30 screws on the sides for the airbag. I was able to loosen one of them (right) easily, but for some reason the other side would barely move.
And yes i was turning it the correct way (same direction as the right side). I ended up stripping the screw and I was wondering if anyone had any suggestions on how I can remove that stripped screw. I was able to loosen it a little but now it's just rounded out. Any suggestions? Thanks
