Tach stoped working....
  • Luis325
    • 3847
    My tach stoped working and i went ahead and installed a spare cluster i had and it did not work either... Also tryed with 1 ETA tach and it did not work.... What can cause this???
    Thanks!!!
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
  • Quadrajet
    • Jul 2008
    • 1278
    Check fuses 10 and 21. Or did you already?
    • Luis325
      • 3847
      Nope!!! I dont know much about these cars... Still learning...
      Are those fuses in the Fuse box in the engine bay?
      Where can i get a fuse diagram?
      Thanks
      • Quadrajet
        • Jul 2008
        • 1278
        Yes those are in the engine bay. Some of the numbers on the cover may still be there so check your cover first.
        If you're looking over the fender at the fuse panel. There should be 8 relays-2 rows of 4. Above them will be fuses 1-15 Left to right. Below will be fuses 16-30,also Left to Right. Be aware that depending on model you may not have all fuse spots used, but they are numbered in sequence and you must count the "empty" spot when trying to find the fuses in question.
