Hey everyone,
One of my buddies is going to try and program a heads up display for his senior design project (computer engineering major) using my e30 as the test car. For the HUD we are thinking he needs to tap into 2 different wires. One that gives the road speed (mph) and one that gives engine speed (rpm).
The HUD unit will be located on the dashboard right behind the cluster bump and close to the windshield. Without tearing into the ECU, are there any wires running to the cluster or otherwise easily accessible that we could tap into?
Is it possible to get those signals directly off the cluster itself? We are just in the planning stages right now and want to figure out the easiest way to get these two signals.
Any suggestions would be much appreciated!
Thanks,
Gray
Thanks,
Gray
