Originally posted by Philo
View Post
Idling issue
My e30 thread...http://www.r3vlimited.com/board/showthread.php?t=120348
The voltage regulator looked fine. It looked just like the one pictured above, fairly new. Any other ideas?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Unplug the coolant temp sensor and run the car again. Report back with findings, sounds like a prime suspect right now.
Originally posted by e30Matt View PostUnplug the coolant temp sensor and run the car again. Report back with findings, sounds like a prime suspect right now.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by blocke View PostIf the car is running poorly when cold, and nice when warmed up..this is usually a bad coolant temp sensor. A new one is like 7 bucks from Pelican. Its worth replacing even if you think the one you have is operating correctly.
ChrisYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Just swapped in one of the ICVs I acquired and it seems to have fixed the idling problem. Started her up, idle dropped to 700-750 and purred at 750. Gave it gas to see if she would cut out like she'd done so many times before, but not anymore, idle dropped to 650, then right back up to stable at 750. Thanks to everyone that said it would be the ICV.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
