Ok, im not sure if these 2 problems are related, but Ill post them anyways. Main problem is the cruise control. it doesn't work. Only things ive checked so far, are the #6 fuse and make sure the C.C cable isn't stuck (its not). Also, my 'Brake light' and 'Rear Lights' check panel lights are pretty much always stuck on. Any idea where I should start?
cruise control not working, and 'Brake light' & 'Rear Lights' check panel lights on
are your brake lights always on? Check the switches on the pedals.sigpic<< wrecked -
I just checked them now, and they were fine. But when i bought the car a few weeks ago, my mom mentioned that it looked as if the brake lights were on the entire drive home. So is it better to just get a new switch, or can this one be salvaged somehow? Do you know the part number?Comment
what are you working on?? (make/model/year) you can also check www.realoem.com
for my 87 (example) the brake switch is 61311368786 and the clutch switch is not listed, as I dont have cruise.Comment
