replacing ECU
  • shields
    • Sep 2004
    • 46
    replacing ECU
    How do I know if my ECU is defective?
    Can anyone walk me through replacing it? I'm not sure where it is on my 1987 325e.
    Thanks
  • ryan_george
    • Mar 2004
    • 331
    Not sure about how to tell if it's defective....
    But it's located in the glove box. Remove the upper cover on the inside of the glove box and there's the Motronic box.
    If you want to replace the chip:
    Take it out of the car, and remove one side of the case (not sure which one right now.) There's a black grommet that holds the circuit board down. Removing it will allow the board to swing out. The chip you are looking for is a 24 pin that is plugged in (as opposed to soldered in). Hope that helps a bit.
    • e304lyfe
      • 807
      you should disconnect the battery before u mess w/ that shit
      • shields
        • Sep 2004
        • 46
        Thanks for the info.
        Would a chip like this do for replacement?
        http://cgi.ebay.com/ebaymotors/ws/eB...category=33597
        • mcgrath
          • May 2004
          • 445
          that chip is for an i not an e.
            • 37833
            Do not buy those fake chips off of ebay. If you want a chip, get a real one from somewhere like www.turnermotorsport.com
            Grover Beach, California
            BimmerHeads.com
            • shields
              • Sep 2004
              • 46
              Part number??
              Does anyone have the part number for the entire box? is it 0261200027 ??
