Annoying sound 2...
  • B2ThaZiZza
    • Aug 2004
    • 614
    Annoying sound 2...
    Most of you may have seen my post about an annoying noise when i press the clutch pedal, it cant be my throwout bearing becuase my clutch was changed not to long ago, about a year next month. All belts have been replaced, new powersteering pump and lines, all oil services are up to date. Most of the failure prone pieces have been replaced, except my water pump. whining noise result of bad water pump? The engine has over 200k and is original. I am the fourth owner of this car, i basically spent enough money to buy an early model e36 on this car. The reason i dont want to get rid of this car is that its is the first car that i bought with my own money so of course im kind of attatched. My old car which was a 93 b18c all motor integra was given to me by my cousin that passed away, i got tired of all the fixit and speeding tickets so i solt the integra and bought the 318is as a commuter and along the way i started liking it more than the integra.
  • Axxe
    • Aug 2004
    • 3355
    When you depress the clutch does the sound go away? If it does, then it's likely your transmissions input shaft bearing. My car does the same thing, kind of a medium to high pitch wine that amplifies when you are in a drive thru or alley. Really annoying, makes the car sound like a beater.
    Keep it slideways!!
