Starting Issues.
  • cr2596
    • 30
    Starting Issues.
    My '89 325i seems to start only when it wants to. When it doesnt want to start, the engine is turning over, it just does not start. It actually seems like it wants to, but it wont. Also, when this happens, the car will do this for an entire day or 2. I can't just walk away from the car, come back in 3 hours, and it will start. It is a huge gap in time that it will fail to start. Then, the next day, it starts right up and will continue to do so, all day.
    With that said, I took it to a local shop for this very reason, and they determined it was the throttle position switch that was in need of adjustment. They did this, and the car was fine, for about a week. I am back to square one, again.
    Any ideas that could help me diagnose this? I greatly appreciate any input.
    Cliffs: 325i intermittently turns over but won't start. Throttle position switch has recently been readjusted.
  • Wishno87
    • 6025
    Im having a no-start problem as well. How is the TPS related? Have you checked for spark and fuel?
      A faulty idle switch in the TPS, or a misadjusted TPS, will cause idle issues, but it should not prevent the engine from starting. A random "crank but no start" condition sounds more like intake leaks or a fuel system problem. But there are other possibilities:
      Idle or hard starting problems are most commonly caused by intake leaks and/or
      a sticky or defective Idle Control Valve (ICV). The only reliable method of
      locating intake leaks is to have a smoke test run on the intake and crank case
      and to test the brake booster with a gage and vacuum pump. The complete list
      of possible causes of an intake leak is:
      Intake boot
      Throttle body gasket
      ICV hoses & connections
      Brake booster, hoses, and connections
      Crank case breather hose
      Evaporative control hose and valve
      Fuel pressure regulator & hose
      Injector seals
      Valve cover gaskets & bungs
      Oil filler cap
      Dip stick o-rings
      Oil return tube o-rings
      While leaks in some of those can be found by inspection or by spraying carb
      cleaner on suspect areas, not finding leaks that way doesn't eliminate the
      possibility. Only a smoke test will really work.
      Once the possibility of intake leaks is eliminated, the ICV needs to be
      removed and cleaned with carb cleaner until the vane inside moves freely. When
      the ignition is switched on you should be able to feel vibration from the
      ICV. If no vibration the ICV is bad, there's a problem with its wiring or
      connector, there's a problem with the TPS, or the DME (or Idle Control Module
      (ICM) on an ETA car) is faulty.
      For the DME (or ICM) to control idle, the idle switch in the TPS must work
      correctly. The switch should close when the throttle stop is 0.020-0.060" off
      the idle stop screw.
      The fuel system should be tested via the suite of tests in the Bentley manual
      as invalid rail pressure can be a contributor to idle and starting problems. A
      simple injector check is to pull the injectors, jumper the fuel relay to run
      the pump, and see if the injectors are leaking. You can also point the
      injectors into a towel, remove the coil wire, and crank the engine to see if
      all of the injectors appear to be spraying in a similar fashion. The best
      approach to possible injector problems is to have the injectors cleaned and
      flow tested. Since raw fuel can or will be released in these tests, have a
      fire extinguisher handy.
      The O2 sensor can be a contributor to idle problems. The O2 sensor is a
      scheduled maintenance item with a useful life of no more than 100k. If the
      sensor has that mileage or more (or is of unknown age), replace it.
      The AFM can be a contributor. If the vane doesn't move freely or the
      resistance track is worn the DME may be receiving invalid data from the
      AFM. And if someone has fiddled with the bypass air adjustment the DME may be
      unable to stabilize idle. The bypass air adjustment should only be adjusted
      per the procedure in the Bentley and with an exhaust gas analyzer. And even
      then everything else associated with engine management has to first be
      operating properly. If the AFM becomes a suspect, replacement with a good used
      unit is the best approach.
      Improperly adjusted or malfunctioning valves will affect idle and starting. As
      can compression issues from ring or cylinder wear. A valve adjustment is
      called for every 15k. A useful diagnostic is to run compression and leak down
      tests on the engine. And aged ignition wires, plugs, distributor cap, or
      rotor can cause problems. Insulation does break down with time and heat. And
      since the youngest E30 is going on 19 years old, if the ignition system is
      original or the plugs are old replacement is indicated.
      Although not usually a problem, a bad DME temp sensor is a possibility. That
      generally won't cause an unstable idle, but can cause hard cold or hard hot
      starts and/or a rough idle. As can problems with the timing reference sensors.
      When all other possibilities have been eliminated and idle or starting
      problems persist, replacement of the DME, or if applicable the ICM, is
      indicated.
      • cr2596
        • 30
        Easily the most thorough response I have ever received. Thank you, Jim.
