Nitrous Systems
  • diegom6
    • 4447
    Nitrous Systems
    I was asking my self wich are the difference btween the wet and dry system also found the port model... here the link
    Deswcription and Chart
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
  • Werksmini
    • 1658
    Nice link, I never knew the difference, not that im a huge fan of nitrous in the first place, but this really clears it up.
    I bombed Korea every night.
    • Jand3rson
      • 37587
      Very cool! I have always wanted to know what the difference was between the 3.
      - Mr. Anderson
      • diegom6
        • 4447
        yap, I think I will buy a kit of wet type Nitrous system for my Stroker Jeep...
        • RedBaron86325
          • 386
          4.6 stroker? Did it used to be the normal 4.0? I'm a jeep fan myself. I have not owned one in a while, but have owned a few. I'd like to get rid of my Chevy Z71 and pick up a nice late 80's Commanche (just before they were discontinued). I was always happy with the 4.0L. I've been through a Cherokee, Cherokee Limited, Islander, Wrangler Renegade (1994 5speed offroad limited edition #504 of 700), and an old Wagoneer. I truely believe that if you can't get there in a Jeep, you probably don't belong there.
          You will almost certainly need a wet system for your Jeep. The fuel psi is fairly low (6cyl) and I can bet being a stroker on nitrous, it would be fairly easy to run lean in the upper rpm band (not that it is that high).
          Jeep on nitrous=Jeep on steroids
          Don't forget the good things Hitler did.
          • diegom6
            • 4447
            Yeah you said ti, this 4.6L pulls very hard, imagine, one day I raced in the sund, like a little drag at two Grands V8 one 5.2 the other 5.9L , I won by two trucks of difference from bot of them...thisroker has a insane torque from very low rpm starting from 1200 RPM....and has 260-70 HP @ 330 LB/ft ...
            Yeah , the bottom is the 4.0L , just need to drop a 258 cranck , 4.2L rods and 4.0L pistons, well I went for a kit , VEnolia forged Pistons, Eagle SIR Rods...CompCam cam, and those things...also biger injectors.. I think if I have a forged parts, the nitrous will safe if is used safely... a memeber of www.jeepsunlimited.com (check this forum at speed freaks board) is using a Nitrous system with exactly the same kit and same setup as me, with manual transmision...
            Hey, drop that LZ1 or whatever , go and buy a used cherokee, year 91' and up (87-90 sucks) dropa kit and you will kick many ases even at your BMW.....these trucks are very lights and has a lot of potential ....yeah, bte I'm a big fun of Jeep, is my favorite truck
            It's a Jeep thing...you wouldn't understand!
            :D
