Bogged on the hwy, won't rev, now won't start.
  • firstRWD
    • 73
    Posted on bimmerforums, but no luck, so hopefully you guys can solve this.
    I was driving along for ~an hour just fine and my car started to occasionally miss. Just one little skip. Then a while later all the sudden it starts bogging down and running like crap. I pull over, check fluids, start it back up, it runs fine, I hesitantly pull back into traffic. A couple minutes later it does it again. It idles perfectly and after idling for a minute it drives fine again. Does it again a couple minutes later, only now it won't rev past ~1500rpm. After sitting for a few mintues, it's fine again. The problem just keeps getting more frequent and severe, revving to less and less rpm when it happens. It wouldn't start for a few days. I replaced the fuel filter, pump, and FPR in that time. Then suddenly one day it starts, running crappy at first but smooths out and runs fine. I drove it around ~20min to make sure. A couple days later while driving it starts doing what it was doing before where it runs fine when I start it, but a couple minutes into driving it starts missing and bogging. After I let it idle a minute it'll run fine for a minute, then start to run like shit.
    A couple days ago it began not even starting again. While it was running really crappy Right before it died, the CEL came on and I get code 1215 - airflow sensor. Don't know if this is related to my problem or maybe just because the car was really struggling to run.
    Here's a vid of it trying to rev the first day it screwed up.
    This is it barely starting after ~5 tries after the symptoms had gotten worse. It smooths out after running a minute.
  • JMPAuto
    • Jul 2009
    • 356
    Check air flow meter, make sure its not binding..
    JMP Autowerkz
    7349 Canby Ave.
    Reseda, CA 91335
    818.457.4967
    www.jmpauto.com
    • wodcutr
      • Apr 2009
      • 2193
      Could be your crank sensor.
      The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
      • newman
        • Mar 2007
        • 1159
        While reading your post my guess was going to be Air flow meter. Then you said you got a code for it. I would guess it's that.
        1987 325is: 495whp/400ft-lb
        UPDATED 03/12/10!: RB26DETT Swapped E30
        • firstRWD
          • 73
          Ok, I've read lots about people having trouble with their AFMs, but I'm having trouble finding out how exactly you can test to see if it's the problem or not. How can I test it to either determine that as the problem or eliminate it as the culprit?
          • gone002
            • 877
            mine had similar issues . turned out to be the crack in the exhuast manifold...
            bimmerboltsandparts.com
            bring back the neeked broads!!!
