Clunking sound coming from rear on right turns.
  • matt_spoon
    • Jan 2005
    • 18
    i've noticed for a while now, a clunking sound coming from the left rear when i take reasonably hard right turns, or fast right sweepers. it seems to be a wieght transfer issue that starts the clunking, but i can't decide what it is. I've been told the diff, but it was swapped out after this started happening for a 3.91lsd and it has continued. i've also been told it's the halfshaft. i haven't replaced that yet, but any other ideas on what this may be?
  • Skafrog
    • 1730
    check your rear shock mounts, and your subframe bushings.
    NASA MidSouth TT Director / GTS2 #018
    Mods: Coastal PS Fluid, 10w40 Oil
    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
    • PeterCip
      • 402
      Had it happen to me, turned out to be the swap bar mount. Check to see if it has ripped out of the body. if so, your bar will bounce into the trunk floor on hard corners.
      The have reinforcements specifically for this problem if it has, in fact, ripped free.
      • matt_spoon
        • Jan 2005
        • 18
        thanks, i'll check all of those things next time i go out to my car.
        • surebimmer
          • Jan 2004
          • 978
          Could be the half shaft/CV axles. I blew one up before.
