Windshield Washer Nozzles
    If I were were trying to replace my nozzle I figure I might as well replace the hose as well. How much hose would one need to replace everything? I am thinking about ordering 2 meters because they sell it by the meter. I feel like this should be enough or should I order 3 meters?
    The hose will be ordered from pelicanparts and is only $2.75/meter.
    Thanks
    '91 318is Alpine II- || HR Sport || Bilstein Sport || Poly RTAB || Treehouse FCAB || Poly Motor Mount || Poly Tranny Mount || Poly Diff mount || IE Sway Bar || BA HP Coils/Wires || 19# Injectors || SSR Comps w/10mm spacers || Hawk Pads || Fog Delete || Magnaflow Exhaust || Z4 3.0 SSK ||
    Would measure it for you but I don't have my car right now. 2 meter is like a little over 6.5 feet, should be enough. You might want to go out to the car to double check though. You can always add in hose from home depot or use a length of the old one if you don't have enough.
      I am just going to ask Pelican when I call to place my order and see if they know.
        I suspect that 2m might be cutting it close. Since the stuff is cheap, get 3m.
          Why not just get it from autozone for the same price? And its local!
          RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
          Welcome e30 (brilliantrot '90 325is) 12/23/06
          DaveCN = Old Man
          My signature picture was taken by ME! Not by anyone else!
          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
            Do yourself a favor..... get the rubber tubing and a 3 way plastic thing. The rubber is easier to bend in the location it all fits in. Plus its all super cheap and easy to fix in the future.
              What is this, "3-way plastic thing" you speak of??? Are you referring to the plastic "T- shaped valve" that splits the washer fluid to the driver & passenger-side nozzles? I need this part! Do they carry it at Autozone??
              OP, I think you can also get the plastic washer tubing at Home Depot or an aquarium store. I ordered about 2 meters from AZAutohaus & it's not enough to do the job.
                cha ching they do carry it at autozone, i picked mine up toda.y.
                1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                1991 325iC - Calypsorot Metallic
                1994 540i - Granitsilber
                Originally posted by scabzzzz
                I've had blunts cock in my mouth, but I'm not gay.
                  Do you think they would carry the hose as well???
