Trunk Battery Ground
  • aaron_silva
    • 1785
    Is this a good enough ground (mounted to the stud of the bumper shock against a painted surface).
    Aaron
  • panasoanic
    • Jan 2005
    • 18
    Did you at least sand away the paint?
    looking for an E30 318is
    • aaron_silva
      • 1785
      No I havent. Is it still a good contact?
      Aaron
      • Rigmaster
        • 3464
        Aaron
        No. You need to sand/scrape away the paint so the battery cable contacts bare steel. Otherwise, you're not gonna get good contact.
        Bret.
        • aaron_silva
          • 1785
          Thank you very much.
          Aaron
          • mcgrath
            • May 2004
            • 445
            Same exact place i grounded mine. i didnt remove any paint and have been doing fine for about 6 months now, but it would be wise to remove the paint anyway.
            • Ryan Stewart
              I Love Miatas
              • 8978
              remove the paint and bolt it on. Then get some primer or even better you can get a clear polymer sealant that is easier to remove but still keeps moisture out of the metal. Spray that over the contact once you have it wrenched down. I did that to the ground from the S50 wiring harness.
              Im now E30less.
