Hello everyone,
I just jumped into E30s very recently but have been a strongly BMW biased person for years.
my new car is a 1987 325ic sport
the few mechanical problems I have are as follows:
1.) the car cranks for a good 10 seconds before it decides to fire and when it does fire, it starts off barely running and gradually works its way up to 550-600rpm where it will idle in neutral, drive or park.
2.) the Idle, I suspect either the 153 ECU, a intake vacuum leak or a filthy ICV because when it idles, it is rough, properly rough, it shakes the car. it will never die, but its rough in neutral or in drive.
3.) not really mechanical related but my left blinker flashes correctly except for when the brake pedal is depressed, the left tail light is out, the left brake light is dim and the TBL is completely out, common place for a wire short?
a few other things that you may or may not be able to tell me
1.) do all coupé seats bolt into a iC?
2.) how do I go about opening a glove box with a broken off handle?
3.) I think my fog light switch is dead, easy way to tell?
Thanks for any help you may be able to offer :)
-Erik
-Erik
