I've replaced my rear glass a few months ago because the defroster tabs on the original glass were no longer attached to the glass.
The replacement glass defroster doesn't work either..
I know for sure it's not the fuse or the defroster switch or the wiring. I get 12 volts at the wiring to the defroster. The problem I think is the unusually high value I am measuring between the two tabs on the glass.
Can someone with a working defroster measure and post what the value is?
I know for sure it's not the fuse or the defroster switch or the wiring. I get 12 volts at the wiring to the defroster. The problem I think is the unusually high value I am measuring between the two tabs on the glass.Can someone with a working defroster measure and post what the value is?
