aftermarket wheel horn button
  • accident
    • 7303
    i bought an aftermarket wheel, and am waiting on the hub. is the horn button easy to wire or is there some sort of hack needed?
    Moral of this story?
  • newman
    • Mar 2007
    • 1159
    It's pretty easy, there is a brass contact ring built into the hub (if you got a momo one). It has one wire that connects to the factory horn button. You may need to add one more wire from the other side of the horn button to ground. Some buttons have the lead, some simply have 2 spade terminals... It doesn't matter which one goes where.
    1987 325is: 495whp/400ft-lb
    UPDATED 03/12/10!: RB26DETT Swapped E30
    • accident
      • 7303
      that was confusing. i know the factory wheel has a contact ring which touches the little springy metal deal on the column. do you have a picture by any chance?
      • accident
        • 7303
        bump
        • newman
          • Mar 2007
          • 1159
          Ah, it's really not confusing at all, but I don't have a pic.
          Just install the hub and tighten the nut. There is one wire leading off it. Hook that wire to the horn button. If there is another wire or tab on the horn button, ground it by using the fitting that comes with the momo hub. Done.
