Misc. M20 2.7i Questions
    1. Let say u usin the eta crank, Wat connectin Rod will should i be using the eta Rods or the (I) Rods?
    2. Fuel Pressure Regulator, if am usin 19lbs injector, which regulator should i use, the one from mustangs or the an adjustable one? and if i get an adjustable one is there a specific one made for the m20? or a universal one should wok?
    3. am plannin on removin my heater,since there is no blower (blower mounting r broken) if i install my motor, wat should i do with the sendin and return holes that goes too the core? block them or connect a holes from sendin to returin lines?
    4. Wat camshaft will u guys advice for a 2.7 buttom end?
    thanx for reading.
    www.stancefactory.com
    I can answer at least the second one. :D
    You can buy any decent adjustable fuel pressure regulator, there isn't an M20 specific one.
      so any universal one will fit?
        They should, double check with where you get it from. Matt325is (turbo guy) told me I could use any unit, just to check with them when you buy it.
          1. Rods depend on pistons, the I rods are 135mm long and the eta 130mm long. Either can be used with the Eta Crank. But the pistons have different pins heights, so your pistons could end up below the deck of the block, over the block, or just right.
          2. any remote adjustable regulator will work, but you need an adapter block to fit the m20 fuel rail. If you handy with a drill bit and Jbweld one can be made with brass fittings from a hardware store.
          3. Just ussing some sort of Hose Splice connect the Hose coming off the back of the cylinder head to the One heading to the Thermostat housing.
          4. need to know more info before giving you camshaft advice, what cylinder head? What fuel injection? etc...
          85 325e 2.7 ITB'd stroker
            am plannin on shavin 3mm of the i pistons. i have access to a machin shop jst wondering how am gonna shave it. its lke the top of the pistons is not Completely flat.
            so any suggestion will help.
            for the cyl. head. ill be usin the I head jst posilished and some new rocker arm. ill be usin a m30 afm as well.
              In that case you want the I rods. Machining them is Tricky. You want to get them clamped into a mill so the piston is perfectly level, Then just slowly remove material in the high sections untill 3mm is gone. I think you won't even tough some parts of the piston. Then once they are shave test fit a piston to make sure you don't need to enlarge the valve reliefs any.(you'll partialy remove part of one)
                thanx i jst need u to explain test fittin once more in more details. i dont get the wordin of it.
                THANX ALOT
                  Simple, once one piston is machined. Install a rod onto it and bolt it to the Crank(no rings needed). Bolt down the cylinder head and get everythign to TDC and install the timing belt. Turn the engine over very slowly by hand to make sure the machine piston won't contact the valves on the I head. The if it does figure out where and remove metal, then you have a template you can do the 5 other pistons off of.
                    Thanx alot men.
                    and back to the cam question wat application will be good for my setup?
                      Don't know, it's realy hard to say. it just depends on what your after. And how lopey and idle you want.
                        to tell u the truth i jst want to get 190 - 200hp out of the m20.
                        i dont know nothin about cam applications. if anyone can recomend one for my application it will be very helpful.
                        thanx alot expecially rs4pro3. u save me alot of money i was gonna take in the pistons but looks very easy 8)
                          a 280/280 is a good middle of the road cam. I was going to go with a 282 in my m30(but decided i didn't have the money) I wish I had now as I did end up having the money. But I've got some other power mods for the m30 planned.
                            thanx again ill update the thrend with pics in a month or so.
