rust in fuel tank!
  • skater335
    • Jan 2010
    • 7
    rust in fuel tank!
    so a few weeks ago i was having trouble with my 84 318i not wanting to rev over 3k rpm. since then i have replaced my fuel pump, fuel filter, and various sensors. turns out my cat was blocked up so i cut the exhaust off. since then the car bogs out all the time when i try to drive it. i pulled the fuel pump out of the gas tank and it was cover in rust! it was really bad! i cleaned it up a little and the car ran better. So ive got a new pump the i bought to put in... havfent put it in yetbut i was wondering if anyone has taken there tank out and cleaned all the junk out of there? how you did it and what you used to clean it out.
    thanks for the help!
  • gothguy70
    • Nov 2008
    • 21
    some radiator shops do gas tanks.A local one hear cleans and reseals them.mine kinda rusty inside.someday i may have mine done.pita gettin down.check the good ole yellow pages for a radiator shop.take your tank out and take it to them.and then maybe you can quit replacing fuel pumps.
    • ZM Blue Devil
      • Dec 2006
      • 13836
      If you are going to go through the joy of removing a gas tank just replaced it.
      Local guy has a brand new one, if interested let me know and I will put you in touch with him.
      L
      Levent
      %20levent@gutenparts.com
      Ladies:
        A twenty year old car with a steel gas tank can have a surprising amount of
        rust in the tank. That rust can and will clog the pump inlet screens and
        filter and cause the high pressure pump to have a short life. While a
        new tank will certainly fix that, you can clean and seal the tank for a lot
        less money.
        My 87 325is suffered from this. The car ran fine on the street but the first
        time I took it to the track for a test & tune it was as if the car had a soft
        rev limiter that decreased by 500-700rpm per lap. Some particulate matter did
        come out of the tank when I drained the gas, but with the in-tank pump out I
        could see a layer of crud in the bottom of the tank that was about an 1/8"
        deep. On the track that stuff got stirred up, clogged the inlet screens &
        filter, and starved the engine. It also ate up the internals of the high
        pressure pump. Rust is a fairly abrasive material.
        The first attempt at a fix was to have the tank acid dipped and install new
        pumps & filter. Either they didn't leave the tank in long enough or the acid
        was a bit depleted, but the result was less than satifactory as the next time
        I had the car on the track the high pressure pump started buzzing and I ran
        into the same starvation issue.
        After taking the tank out again and sloshing about a gallon of fuel around I
        got loads of rust out of the tank. The new filter was heavily loaded and the
        inlet screen of the high pressure pump was also loaded up. And the cross-over
        pipe was completely plugged. This time I was determined to get all of the rust
        out and follow that up with sealant to lock down anything that was left and
        prevent further rusting. I used a gas tank sealer kit from Eastwood, but went
        a bit further than they suggest.
        The tank, having been recently acid dipped had no varnish in it. So a simple
        wash with a strong TSP solution removed the remaining organics. I made up a
        simple plug for the hole where the in-tank pump mounts that could easily be
        removed. Think of a round disk of plywood with a bar on the bottom and a couple
        of screws to snug the bar up. Drop that into the opening, rotate slighty to
        engage the lock ears on the tank and tighten the screws. The remaining
        openings were closed up with pieces of a freezer bag held in place with rubber
        bands.
        About a gallon of diluted acid in the tank was about right. That was enough to
        slosh around well but not so much as too make the tank to heavy. I used an acid
        mix sold for cleaning masonry that's composed of Hydrochloric and Phosphoric
        acids at about double the normal dilution. Over the course of a couple of
        hours I'd slosh and flip tank every fifteen minutes to wet all parts of the
        tank with the solution. At the end of a couple of hours I drained the tank and
        disposed of the pretty well spent acid by reacting it with limestone gravel.
        To flush the tank I made up a right-angle spray nozzle with plumbing fittings
        and a 1/4" hose barb. That allowed the nozzle to be inserted into the tank and
        a high velocity stream sprayed into all corners. This was done with the tank
        at about a 30deg angle (drain plug hole down) and the fluid collected into a
        bucket. When the water ran clean and no more loose junk came out I repeated
        the acid treatment and flush. It took all of one Saturday and part of Sunday
        to get the tank to the point that no more rust could be seen and nothing was
        being flushed out of the tank.
        The last steps were to use the acid etch from the Eastwood kit, flush with
        acetone, and apply the sealer. Before putting the sealer in the tank I removed
        the cross-over pipe and sealed those openings. And after the sealer had been
        applied and before it had a chance to harden I blew out those openings and the
        tubing that runs across the top of the tank with compressed air. After drying
        for a couple of days the tank was reassembled and reinstalled in the car.
        Once sealed the inside of the tank had a fairly uniform white coating. I did
        see a few specks of matter that I wasn't able to flush from the tank, but
        those were well locked in place by the sealer.
        Cleaning and sealing the tank is pretty labor intensive. But at a total cost
        of less than $80 it is a lot cheaper than a new tank (~$300 for this car).
