Blowing lots of smoke!
  • E30godz
    • 1524
    Well when i put the turbo on i got a custom exhaust made all the way out to cat-back, so it 'Y's out from 1 pipe to two pipes into the brullen muffler...so i dont have any cats....i also did the Mustang oxygen sensor around the same time. well at idle my car just bellows smoke out the tail pipe...maybe while driving too, but i cant tell. Is this just because the lack of a cat?
  • peerless
    • 285
    smokin!
    well you kinda need to tell us what color smoke. In general its like this:
    Blue Smoke = burning oil
    Black smoke = running too rich
    White smoke + smells like coolant = you guessed it, burning coolant.
    White smoke + cold temperature = normal condensation
    Maybe your car runs rich and the cat was cleaning this up, now you have no cat to burn this off?
    Robert
    85' 325e
    • E30godz
      • 1524
      well it HAS been really cold lately....and it looks white... hrmm ive never had any trouble with burning coolant....and maybe just a little bit of oil....hrmmm must collect more info
      • Kavkazia
        • 394
        Is it heavy smoke? You smell any sweet from your muffler?
        How much boost you're running?
        95' M3.
        90' 325i Turboed.
        87' 325eS Fixed.
        • E30godz
          • 1524
          not boosting yet, up-pipes still need to be made, the turbo is attached and spooling though... as to if the smoke is heavy or not...i would say its about medium as oppsed to just bellowing out...not sure about the smell..i may go give it a good flogging and maybe burn out anything in the tail pipes that was left there when i was running without the o2 sensor
          • E30godz
            • 1524
            apparently, that worked...i went and beat the shit out of it and the idle improved...the smoke went away...and it showed two more hg/inch vacuum on the boost gauge. ; )
