Wiper Woes
  • DanMan68
    • 204
    Wiper Woes
    So the other day my right side wiper was frozen to the windshield. I accidently hit the wipers and only the left side actuates. So now, after everything is unthawed only the left actuates and the right just kinda wiggles but doesn't move. So am I screwed? Or is there a replaceable pin or something that I can just swap out that is designed to let the wiper break away for just such a circumstance.
  • hoseklamp
    • 214
    Does the pin move inside the wiper arm at all when you turn them on?
    If so, did the pin or wiper arm strip?
    • DanMan68
      • 204
      You tell me lol? Idk, it happen recently and I haven't had a chance to take a close look at it yet. I just know the left wiper isnt working.
      • dannyg
        • Mar 2007
        • 1553
        My crystal ball says the pin stripped and you are fucked.
        1993 325ic Schwarz/Natur
        1991 318is Black/Black - Slicktop - Project s52
        1989 Alpine White/Black M3 S52
        1988 Henna/Pearl M3 <3
        • DanMan68
          • 204
          how do I de-fuck my self then?
          • hoseklamp
            • 214
            You could try tightening the nut down that holds the wiper arm on...
            • e30frosh
              • Dec 2004
              • 2170
              I had this happen once. I tightened the wiper arm and fixed the problem.
              Every day I wake up we drink a lot of coffee and watch the CNN
              Every day I wake up to a bowl of clover honey and let the locusts fly in.
              Lobsterbacks attack the town again
              Wrap all my things in aluminum
              Beams of darkness streak across the sky
              Pink rays from the ancient satellite
              Every time I look out my window same three dogs looking back at me.
              Every time I open my windows cranes fly in to terrorize me.
              • dannyg
                • Mar 2007
                • 1553
                I don't know. Want me to ask the crystal ball?
                • DanMan68
                  • 204
                  Sure whatever works ;)
                  • ck_taft325is
                    • Sep 2007
                    • 6880
                    Doooo iiiiiittt.
                    Need a part? PM me.
                    • AndrewBird
                      The Mad Scientist
                      • 11897
                      You probably stripped the splines out of the wiper arm. A new wiper arm should fix the problem.
                      Unless you stripped the splines on the wiper regulator. Then you need to replace that, which is much more work.
                      • txtorquemade
                        • 1758
                        Either way kinda sucks, cause I did the same thing last week.
                        sigpic 1987 325is
                        • scottinAZ
                          • Dec 2009
                          • 1312
                          Do the arms even have splines?? Mine is mounted on a tapered shaft. tightening it works wonders.
                          I saved 15% on my Bimmer parts by switching to ...
