squeaking coming from front of the engine
  • NC325iC
    • Mar 2004
    • 6565
    first off id like to say that i dont think its a loose belt.
    i was thinking it might be a bad fan clutch or a bad bearing somewhere.
    can anyone confirm this or give me an idea of whats wrong?
    thank you
  • NC325iC
    • Mar 2004
    • 6565
    maybe i shouldnt have said thanks
    • kansas-ix
      • Jan 2004
      • 1600
      be more specfic and help will come, a squeak huh, not a belt huh, as far as bearings in the front of the engine there is the tensioner bearing, and thats all of my input.
      E30 325ix 62k
      • DaN
        • 1265
        The belts are probably just old and dry, spray each one while its running with carb cleaner or wd-40, if the squeek goes away, then get new belts. If they are tight.
