List of to do anything else?
    OK so right now im buying these parts: Clutch kit, all trans seals, subframe bushings, trailing arm bush, shocks, h and r sports, and diff seals and rear brake lines. Is there anything else i should have replaced while im gettin this done? I would do myself but i dont have the time, or proper tools for the clutch install. Also if any of you guys have some of the parts above beside subframe bushings and springs let me know. Thanks Hunter
    shifter bushing stuff and maybe a Zx shifter.
      a zx shifter?
        Originally posted by e30loverSC View Post
        a zx shifter?
        he means a z3 or z4 shifter
        1989 cirrisblau-metallic 325i
          oh ok what the best short shifter to put in? and do those need to be modified.
            driveshaft flex disc (guibo)
            driveshaft center support bearing
            be sure to do both inner and outer [rear] brake lines
            maybe the wheel bearings(?)
            -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
              new decison im going to get the mechanic to do clutch and subframe ill do the rest on my own.
                So whats the deal on the short shifter
                  search, read the shifter thread...it has all the info you'll ever need/want
                    300zx shifter is what he REALLY means.
                    Ma che cazzo state dicendo? :|
