Ok, so its almost that time of year here again in AZ, and the AC needs to be working. I have the full system installed in the car, and electrically tested, however it has a leak somewhere. It is still set up for R12, and has the Behr/Bosch compressor in it still. No signs of leaks or failure of the compressor, but I have read that this type of compressor is incompatible with R134A. Without going too deep into the system, I want to convert and recharge the system with 134A, as I can do it myself without a license, and if I blow a line, or the compressor turns to shit, Im not out much. I am familiar with the procedures of a retrofit, so that isnt the issue.
Now for the questions.
1) does anyone know why the original type compressors are incompatible with 134A?
2) one of the pressure switches on the reciever dryer is no longer used, do I need to jumper the wires together, or leave them open circuit?
I will do a full retrofit if I need to, if and when the rest of the system is proven good, but im not gonna drop 500 bucks into a retrofit kit if the condenser or evaporator is shit (without knowing it first)
also anyone with experience on the retrofit compressor kits, I would like to know where you sourced it from, cheapest I have found is about 450 bucks, and uses a sanden 508 compressor. I see that it needs a new bracket, but I dont see the provisions to adjust the belt. pics, and or a decent description including how complete and trouble free would be nice. I can part shit together on my own, I dont need to pay someone for a half assed "kit" to do it for me :D
