Humming noise
  • Massimo
    • Jan 2008
    • 3207
    Humming noise
    Basically when i go over 65km/h i get a humming noise from the rear of the car. I am assuming it is the wheel bearings but just wanted to check to see if there are any other known problems that produce the same noise.
    Thanks Guys
  • 87-325ic
    • Apr 2006
    • 1198
    if it is whiny at all it could be the Differential.
    • ///digitalme
      • Dec 2009
      • 2088
      humming coming from the back...um...i have that same problem on my 318is but i know its the differential support. although i had something similar on my old e30 too and turned out to be the driveshaft
      • 84E30
        • 456
        I have the same noise when im on the freeway..loud n annoying humming noise...
        Its your wheel bearing..
        Check out my Insurance Thread
        http://www.r3vlimited.com/board/showthread.php?t=164190
