Auxiliary Fusebox Help
  • Japandrew73
    • 2164
    For those who have the auxiliary fusebox that has the blue box with the two bullet fuses, could you help me out? I know that one wire is wired hot on ignition, and the other wired hot at all times. But where do these wires tap into? Anybody who has one of these auxiliary fuseboxes and could take a look would help me a ton, thanks!
  • kronus
    • Apr 2008
    • 13028
    I'll take a look in a few hours, pending some sleep.
    cars beep boop
      I believe that the switched connection taps into the hot in run & start wire off the ignition switch. The unswitched wire taps into the main power lead into the fuse box.
      • Japandrew73
        • 2164
        :oops: That would make sense, thanks for the help I know exactly what to do now.
