On the accessory wiring harness coming from the fusebox that has your headlight wires, foglight wires, washer wiring, etc., when you get to the connector for the power to the washer system which is a purple power and a brown ground, bundles with it is a black with white stripped wire that goes to a little one pin connector. What the hell does this wire do?
Hopefully this was better of a description.
If not I can take a picture tomorrow.
I tried tracing the black with white striped wire back to the fusebox but it doesn't go all the way.
