Stomp Test Doesn't Work
    Anybody ever have this problem? Alright, so I had a check engine light when I would come to a stop at idle. I bump the throttle and the CEL will go away. I figure it's the o2 sensor going bad. When I got home I did the stomp test, but nothing happened when I did the stomp test. I know I have done this test on this car before and it worked. I don't know why it doesn't.
    So the next morning it had a rough idle then dies, I get to work and clean the o2 sensor. I tried the stomp test again, and it still doesn't work. I clean the o2 sensor, drive the car out. After work I start the car and it runs fine. So I turned it off, and did the stomp test once again and still nothing.
    I get home run the Peake scan tool on it to find code: 0A - Emissions (Lambda) Control. My conclusion is the o2 sensor, but my question is... how come the stomp test doesn't work? I KNOW I am doing it correctly. Anybody have this problem before?
    Paypal: vdang5@gmail.com
    Delta Auto Care
    2875-C Towerview Road
    Herndon, VA
    703.435.1375
    My Feedback Thread: Evil_Twin
    The WOT switch in your TPS is probably dead, you can test it pretty easily with a meter.
    '89 Alpine S52 with goodies
      I don't know about your problem but I had a issue last summer where my car had a rough idle and a cel, i tried the stomp test and it never worked either. The problem eventually corrected itself though so I dont know what caused it.
      Flickr
      @michael.colby on Instagram
      "All he needed was a wheel in his hand and four on the road"
        I'm thinking it might be the TPS WOT is dead too. We'll see, i'll get some more testing done tomorrow.
        Delta Auto Care
        Herndon, VA
        703.435.1375
          ...doesn't work in my 89 325is either, but does in my ix.
            yah, but it HAS worked before... lol thats why it's weird.
            Delta Auto Care
            Herndon, VA
            703.435.1375
              If either the idle switch or the WOT switch in the TPS isn't working, the stomp test won't work.
              Having the CEL come on at idle and go off when you open the throttle and having a Lambda fault strongly suggests intake leaks. The O2 sensor could also be part of the problem if it has 100k on it. The useful life of an O2 sensor is only 100k and the sensor should be replaced at that mielage as a routine maintenance item.
                Yah. I really don't believe it's an vacuum leak because if it was a vacuum leak it should happen all the time (just about). I cleaned the o2 sensor, and the CEL hasn't come back. I think I'm just going to push it a bit more because a new motor is going to go in soon.
                Delta Auto Care
                Herndon, VA
                703.435.1375
                  I've seen this on several occasions and every time the cause has been intake leaks. So I'd bet on it being the case here also. The only sure way of finding intake leaks is to have a smoke test run on the intake.
                    I just put a new intake boot on not too long ago.
                    Delta Auto Care
                    Herndon, VA
                    703.435.1375
                      That is only one of the potential causes of an intake leak. The complete list of possible causes of an intake leak is:
                      Intake boot
                      Throttle body gasket
                      ICV hoses & connections
                      Brake booster, hoses, and connections
                      Crank case breather hose
                      Evaporative control hoses, valve, and expansion tank
                      Fuel pressure regulator & hose
                      Injector seals
                      Valve cover gaskets & bungs
                      Oil filler cap
                      Dip stick o-rings
                      Oil return tube o-rings
                      While leaks in some of those can be found by inspection or by spraying carb
                      cleaner on suspect areas, not finding leaks that way doesn't eliminate the
                      possibility. Only a smoke test will really work.
                        This is interesting, as Ive suspected an intake leak for some time on my car, but cannot find it by the usual starter fluid spray test. Whats a smoke test consist of, and is there a home-based kit, or whats a shop usually charge?
                        Parts Wanted
                        The Never-ending Resto Mod
