The past month, I've had to jump start my car three times. The first two were close together, so I had the battery tested at a shop and the mechanic said the battery wasn't my problem. Then with a friend, I tested the alternator and regulator per the bentley manuals instructions, and that came up fine too. Then after a few weeks of no problems, it suddenly happened again. I drove about 3 blocks to the gas station, spent a few minutes putting air in my tires, and when I went to start the car, I found the battery dead. I don't drive my car all that often, maybe 5 or 6 mile drives a week, and the weather has been a little cold here...could that combination be causing my problem? Or is it more likely the battery itself, and should I get a second opinion as to whether or not I should replace it? I know next to nothing about a cars electrical system, so any input would be appreciated. Thanks in advance.
Danny
Danny
