spark plug pic- what is going on in this cylinder?
  • clydesdale
    • 631
    This is from the cylinder that is second closest to the firewall. I end up needing a new plug every 10 thousand miles. This plug has only about 8 thousand miles.
    Automatically change your Windows desktop background and Mac wallpaper from a curated 5,000+ HD & 4K library. A real upgrade from Windows Slideshow and Windows Spotlight. Free trial; works on Windows 10/11 and macOS.
  • SpecM
    • Oct 2005
    • 4531
    carbon fouling
    maybe a leaky injector or intake valve stem seal?
    1989 cirrisblau-metallic 325i
    • clydesdale
      • 631
      It appears part of the insulation around the electode has disintegrated.
      • AndrewBird
        The Mad Scientist
        • 11898
        That doesn't look like carbon fouling. Way to white. Looks more like pre-ignition problems.
        • clydesdale
          • 631
          That is what my brother said. What causes it?
          • clydesdale
            • 631
            Well, I have some new info. I pulled all the plugs:
            #1. clean
            #2. clean3
            #3. white deposits and part of insulator broken
            #4. just replaced, but the old one had white deposits and broken insulator
            #5. replaced last year and now has white deposits
            #6. clean
            The plugs and wires have about 60k on them.
            • bddog
              • 351
              Pre ignition, cross firing- Incomplete ignition is what my book says- Your pic looks just like it
              • clydesdale
                • 631
                I am unsure of the cause. Any ideas?
                • tn325i
                  • 1154
                  Not being a smart ass but I think you answered your own question... Plugs nor wires should be run that long..
                  • clydesdale
                    • 631
                    I do not think it is just a simple plug change. One of the plugs has been changed twice during that time because the cylinder stop firing. There are 3 plugs in a row that have insulator damage, the other 3 plugs are fine.
                    OK, I have a minor update. I did not do the compression test yet, but I did replace all the spark plugs. The stumble is now completely gone. The car drives great. But, obviously I know the problem did not go away. So, does this change anyones potential diagnosis? I know it is not one single injector anymore, as there are 3 plugs that were screwed up. All 3 cylinders are in a row, 3,4,5. I am hoping to get a compression test this weekend or next.
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      If I remember right, the injector harness is split up into 2 banks of 3 cylinders (someone correct me if I am wrong). I would check the harness for cylinders 3, 4 and 5 and see if there is anything obviously wrong like missing insulation on wires.
