quick question!
  • dnova89
    • Aug 2009
    • 851
    quick question!
    just need to know real quick, i'm ordering up all the parts for a major service and I need to know how many cam seals to order. does the m20 have 6 seals/orings? i don't think so because i noticed some other v6 engines only have 4 and some other 4 cyl engines only have 2.. so I wanted to make sure I don't over-order. i want to replace all of them. thx for the advice i'm up ordering the parts right now so I hope someone is still awake to give me a quick answer! haha
    I'm guessing that since it's a straight 6 engine there is only 1 cam seal? I'm still learning so have mercy :)
    thanks,
    darius
    -Darius (aka DiscoDoughnuts on other forums)
    dude man bro...
  • 884door
    • Nov 2008
    • 380
    That's correct, only 1 cam seal.
    • dnova89
      • Aug 2009
      • 851
      Alright thanks a lot 884door, also one more question. Any other hoses I should be replacing besides the radiator hoses when doing a timing belt/water pump/ thermostat change? I'm seeing on pelican parts theres like water pump to thermostat hose, thermostat housing to throttle housing, and thermostat to water pipe hoses. should i grab those too?
      dude man bro...
        Unless the hoses are fairly new, it would be best to replace all of the cooling system hoses.
        • dnova89
          • Aug 2009
          • 851
          so did I get all of them or am I still missing some? I got the lower/upper radiator hoses, water pump to thermostat hose, thermostat housing to throttle housing, and thermostat to water pipe hoses.
          i didn't get the expansion tank hoses yet though, are those the only ones i'm missing?
          dude man bro...
