chassis ground locations
  • gwb72tii
    • Nov 2005
    • 3864
    did the search and couldn't get a hit
    anyone know the locations for the chassis grounds?
    specific problem is intermittent fuel pump operation and we're just trying to chase down all suspects.
    thanks
    BTW - 1991 325ix which i assume is the same as a 325i
    “There is nothing government can give you that it hasn’t taken from you in the first place”
    Sir Winston Churchill
  • SpecM
    • Oct 2005
    • 4531
    sorry I don't have anything to say about the grounds
    but the intermittent fuel pump issues I've seem stem from flaky FP relays. Not sure if that's your problem, or if you've ruled it out or not. If you haven't yet, check into it.
    good luck either way
    1989 cirrisblau-metallic 325i
    • gwb72tii
      • Nov 2005
      • 3864
      yes, we replaced all the relays and the cps
      thanks
        There are a number of chassis ground locations. The ones of interest in this case are the DME ground on the right shock tower, and the fuel pump & sensor ground under the rear seat on the left side of the car. And, of course, the main battery ground.
