Squeeky clutch pedal
  • royalflush313
    • Mar 2004
    • 2070
    Car drives fine, gears engage fine. But when I press/release the clutch pedal, it is making a slight squeak.
    Any ideas what might be causing this, and how I may go about fixing it?
    TIA
    ~ Go Canucks Go! ~
  • bkelsey86
    • 1173
    could just be the jonts need some good old lube. us tput some oil or lube around the pedal and all teh pivot points mine used to do it but this stopped it.
    • royalflush313
      • Mar 2004
      • 2070
      that was it. Just took off the knee bolster and sprayed a little bit of crc and the problem is gone. Thanks.
      ~ Go Canucks Go! ~
      • surebimmer
        • Jan 2004
        • 978
        Ya good old lube will fix alot. My gas pedal on my 325e was a bitch to push in. Lubed the TB cable and now nice and smooth.
        • royalflush313
          • Mar 2004
          • 2070
          yep. Lube and duct tape fixes just about anything :D
          ~ Go Canucks Go! ~
          • hamann318is
            • 3382
            Rules of house (and car) repair.
            If it moves and it shouldn't, duct tape. If it doesn't move and it should, WD-40. ;)
            The BMW 318 is back. With a vengeance.
            • royalflush313
              • Mar 2004
              • 2070
              well the lube was a temporary fix. The squeak is back :?
              Can anyone recommend a good all-around lube that I could use instead of WD-40 and the alike?
              ~ Go Canucks Go! ~
              • E30godz
                • 1524
                get some white lithium grease in a spray
                my door was SKREAKING (not squeaking) and i sprayeed some liberal amounts of it on the door arm hinge about 7 months ago and it hasnt made a noise since.
