Found something interesting in the Bentley...
    There's been some discussion of converting a dual-mass flywheel equipped car with a single-mass flywheel.
    I understood previously that all you needed for this swap was a Single Mass Flywheel, a Single Mass Clutch and Pressure Plate and the correct throw out bearing.
    I was looking thru the clutch section of the Bentley today, and it said that the Dual-Mass flywheels use 22mm slave cylinders, whereas all others use 20mm slave cylinders. The master's are the same, but accoridng to this - the slaves are different depending on whether or not you have a dual or single mass flywheel.
    I just purchased a new slave cylinder - whatever one is usually required for my car - so I'm afraid I may have the slave cylinder for a dual mass flywheel and not a single.
    Sooo - I was posting this up to see if someone could set this straight for me. Did I misunderstand this - or is this true? Do I need to purchase another slave cylinder that's made the work with a single-mass?
    Thanks!
    - Sean Hayes
    According to the Pelican Parts website, the Slave Cylinder is the same for ALL E30 models. Soo - I'm leaning towards that right now.
    Any other input? ;)
    - Sean Hayes
      have you checked with the ETK ?
      ~ Go Canucks Go! ~
        I just checked. Looks like they are all the same. 21 52 1 116 300
          Ok, must have just been worded very poorly in the manual. :shock:
          Cool. 8)
          On a lighter note - nice sig Ryan! :D
          - Sean Hayes
            Cool. 8)
            I was trying to show off how salty my car was. Don't know if you can tell too much, but it does look pretty good.
