gasket q
  • boostboss
    • Apr 2004
    • 37
    gasket q
    quick question, should there be a gasket that sits in between the oil pump and block on the 85 318i m10b18.?
    Cheers. T
  • DaN
    • 1265
    I don't believe so, my 325e didnt have one.
    There is some kind of spacer, or shim that's used. Just looked it up to see if there is a gasket listing. none
    • AdamF 88iS
      • 2051
      It's a shim. You put thicker ones in to take slack out of the chain.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • boostboss
        • Apr 2004
        • 37
        thanks, got the shims in the gasket kit. cheers.
