Any way to know how much fuel in tank?
  • Jean
    • 18228
    #31
    E30 clusters aren't THAT bad right? :)
    • Jand3rson
      • 37587
      #32
      Nope, I've actually gotten quite good at pulling/reinstalling the thing.
      Matt, was your tach doing the same thing?
      • e30Matt
        • 5077
        #33
        It was originally completely dead, then it would start jumping from 0 to 2000rpm when the engine reached that point and "skip" up the scale, then fall back to zero. I replaced the 6k tach with a 7k unit that was originally out of the '87 cluster I was using, and no problems now. I'm planning on doing the 885 head swap along with a bottom end rebuild in the next month or two, so I went ahead and threw the 7k unit in.
        • Jand3rson
          • 37587
          #34
          Yeah, mine will jump up to 2k when I start the car, and unless I wind it up to (what I suspect is) about 3k, it falls down to 0, then goes back up to 2k. Then it will start working normally, and work fine until the next time I drive the car. But I have a new one on the way, so that should take care of it.
          • accident
            • 7303
            #35
            you know the needles come off, right?
            anyway, if you have a 13 button OBC you can hit the 1000 and 1 buttons together and it will tell you the amount of fuel in liters.
            Moral of this story?
            • Jand3rson
              • 37587
              #36
              Yes, I know the needles come off.
              And reading the first post pwns you.
              • Jand3rson
                • 37587
                #37
                So Matt, you were absolutely right! Swapped in the new fuel gauge and it works perfectly, as does the tacho.
