Oil Pan gasket
  • PeaveyBassist
    • Sep 2004
    • 3511
    Oil Pan gasket
    How long does it take you guys to change an oil pan gasket? I believe mine is leaking. At least thats what it looks like to me. I dont have a lift, just jack and jackstands. I looked through the Bentley and it doesnt look like its too hard of a job. Just unbolting the steering rack and front subframe. You dont have to lift up the motor or anything do you? Does anybody have any tips for getting it done quicker/easier?
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • PeaveyBassist
    • Sep 2004
    • 3511
    Is there anything else that I should change like a "while I'm in there" sorda thing?
    Will
    DaveCN = Old Man
    • Jand3rson
      • 37587
      My write-up on changing the M20 oil pan. Disregard posts following the intial write-up, mentioning steps that were not needed. The write-up was edited and re-written.
      This write-up was intended for chaning the oil pan, but it's the same procedure to change the gasket.
      • PeaveyBassist
        • Sep 2004
        • 3511
        If you dont hoist the engine up, can you get the oil pan out without removing the pump? Did you unbolt the steering rack? Or did you leave it attached? I know in the writeup it doesnt say you did but I wanna double check. The Bentley says to unbolt the steering rack, and the bellhousing, and thats pretty much it. It doesnt mention hoisting the engine or anything. I would rather unbolt the steering rack compared to hoisting the engine up. What do ya think?
        Will
        DaveCN = Old Man
        • Jand3rson
          • 37587
          No.
          Will
          The way the Bentley tells to do it, you have to remove the oil pump.
          • PeaveyBassist
            • Sep 2004
            • 3511
            So the easiest way to do it is hoist up the engine?
            Will
            DaveCN = Old Man
            • SR20Fastback
              • Jan 2005
              • 424
              yes, you must hoist it up. Start by putting the brace on the fenders/engine, then undo the control arms on the back side (2 bolts each arm) then take the motor mount nuts off, now disconnect all 4 nuts for the front swaybar, then the 4 subframe bolts. Then lift the engine as much as possible. After that, its just a struggle on your back. If you can somehow use a lift, DO NOT PASS IT UP.
              I just finished doing an E36 oil pain this morning, it was not fun on the ground.
              • Jand3rson
                • 37587
                You don't need to unbolt the subframe or the swaybar, just the control arms from the frame.
                And what are you talking about when you say "the brace on the fenders/engine" ? All you have to do is jack the car up, and put it on jackstands.
                • PeaveyBassist
                  • Sep 2004
                  • 3511
                  so... control arms from the frame come off, motor mounts come off, bellhousing comes off,m otor is hoisted up, oil pan comes off. Dont need to loosen the tranny mounts? Dont need to unbolt the steering rack or the subframe?
                  Will
                  DaveCN = Old Man
                  • e30325ic
                    • Dec 2004
                    • 491
                    I did 2 different oil pans. One for a gasket and one for a busted pan. I just unbolted the engine mounts and jacked up the engine as far as it would go and put blockes under the engine mounts. This gave me the clearance I needed but I still had to remove the Oil pump but I neve touched the steering rack or cross member. I took about 2 1/2 hrs with out an overhead rack and no air tools.
                    1990 E30 325ic (sold for more than I paid for it after 5 Years)
                    1995 E30 325e (in progress)
                    1987 E30 325is (totaled)
                    1990 E30 325i
                    1991 E30 318is M50 PWR
                    1996 E36 328ic
                    1997 Z3
                    2006 F150 Super Crew 5.4L 6.5' bed The work horse (need something to drag all these old BMW's home for resurrection.)
                    • Rich V
                      • Oct 2004
                      • 69
                      Doing an oil pan on an E30 with an M20 is different than an E36 with an M50/S50.
                      • Kilomph
                        • Oct 2004
                        • 599
                        I didn't hoist the engine, I didn't see the need to spend the extra money to rent one when it wouldn't be worth it.
                        I didn't everything this guy did
                        He's got an auto, but i'm sure you can figure it out...
                        • Dave
                          E30 RAT
                          • 11675
                          It seems there is no consensus on the best way to do this. I think I'll rent a hoist - seems like the safest bet.
                          Current Cars
                          2014 M235i
                          2009 R56 Cooper S
                          1998 M3
                          1997 M3
                          • arsevader
                            • May 2005
                            • 1025
                            I'm not clear on why you have to unbolt the Control Arms. Or am I an idiot? Wow I just realised how old this thread is.
                            • Dave
                              E30 RAT
                              • 11675
                              I love tha Avatar, dude. She's a Maneater . . .
                              Current Cars
                              2014 M235i
                              2009 R56 Cooper S
                              1998 M3
                              1997 M3
