Convertible Weight Ballast
    If I replaced this literally 50lb lead weight in the trunk with the battery bolted in, would I have the same supposed counterbalance the weight supposedly provides?
    -Grif
    My car eats bentley manuals.
    -Grif
    To answer your question: No
    To answer the question you should have asked "is it noticeable": No
    Do it
      ive been driving around without it for a while, never noticed the difference. I would like to put the battery in the trunk
      88 325ic ~~~> Rusty and ugly
      85 E ~~~> RIP
        i have put my battery there, and now it wouldnt off set cause you remove 50lbs and then you move 50 lbs back, so basically you removed 50lbs from the front instead
          Where does one find this lead mine?
            rear right corner, where the battery would be
              i recently moved this chunk of dark matter from my parts storage area.
              Seriously, why is it so heavy and what kind of engineering is that?
              PS, i removed it when i moved my battery to the back.
                its for when the convertible top is down.
                helps keep the car 48/52 weight ratio/ balance
                you could also add a big 15"dvc subwoofer (like me).
                and some pro3 or track e30s like those weights, b/c they have bmw printed on them, and they already have bolt holes, a perfect 50lb balast .
                so bring em to the track and give em away
                3 pedal club
                200,k+ club
                cabrio club
                port-matched- polished- purring www.BMWpark.org
                </div>
                linux since 1999
                  it's not a vibration dampener like in the e36 'verts, is it? In my vert, I'm required to use a vibration proof battery because of this.
                  1997 540i/6 - stock
                  1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
                  1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
                    is that why girls love riding in my car ?
                    3 pedal club
                    200,k+ club
                    cabrio club
                    </div>
                    linux since 1999
                      This sounds like the best explaination so far. Maybe thats why the battery is in the front where it should be...to counteract the ballast when the top is down.
                        its p/n says its a vibration damper.
                        most people agree with the ballast thing too though.
                          We have complete uncut line we sell to the 2002 customers for relo. If you need one let me know.
                          Levent
                          %20levent@gutenparts.com
                          Ladies:
                            I'm not clear on what you're saying when you say uncut line, you mean to relocate the battery?
