so whenever i turn my car on, since the day i got it. the engine oil and coolant light stay on at all times no matter what. the levels are fine in both. i know where the coolant level sensor is but where is the oil level sensor, and would this be the problem?
Check Panels Lying
Check Panels Lying
Originally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.Tags: None -
Oil level sensor is on the drivers side of the oil pan. Check the connection before you up and replace it.sigpic
Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677 -
ill look into itOriginally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.Comment
My engine oil, rear lights, brake lights, and washer fluid all stays on. I've done tried replacing some of it, it's a broken connection and loose connection.I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Paypal: vdang5@gmail.com
Delta Auto Care
2875-C Towerview Road
Herndon, VA
703.435.1375
My Feedback Thread: Evil_TwinComment
My connection to the back of the check panel has been loose for a while. I got tired of all the lights being on so I unplugged it. Fixes it permanently. :)
"See, we're adding a little something to this month's sales contest. As you all know, first prize is a Cadillac Eldorado. Anyone wanna see second prize? Second prize is a set of steak knives. Third prize is you're fired."Comment
