I got a 1990 325is
Monday morning had all the lights in the cluster light up Monday after work Head lights were dim wipres moving slow.
Tuesday got battery tested and it failed got new one. checked alternator and it was low voltage so I took it out had it tested and it failed. Bought new one. it the dreaded Atozone rebuild but I tested it after the install and it outputs 13.5 Volts at 1500 RPM with everything on.
Now the Battery warning light comes on after I turn the ignition switch off.
Battery was dead next morning. Jump started the car drove 25 miles. Light did not come on during the drive but right after I switched the ignition off there it was.
I have been disconnecting the battery between drives for now. I'm going to check my ignition switch this weekend but if anybody else has any other suggestions I'm open to them
thanks
thanks
