Complete Tune-Up - What should I do? (318iS)
    I recently got a '91 318iS. Car is 100% stock and runs pretty strong. However, sometimes it idles weird and just feels a bit tired. I think I need to do a full tune up.
    Here is what parts I ordered so far:
    New pads and rotors
    Rear shock tower mounts
    Chain tensioner
    Oil filter
    Will order soon:
    NGK plugs
    What else should I do?
    My Seller/Buyer Feedback
    Performance Aftermarket Parts & Accessories
    mileage?
    Originally posted by FredK
    However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
    My year in Germany
    Feedback
      205k
        Do you know when the timing chain/guides were last changed? If not...maybe just do a visual inspection and replace if needed. Also look for sprocket/tooth wear
        My year in Germany
        Feedback
          There's a "mess under the intake" thread on M42 club. That should solve your idle isse. The M42 is very sensitive to vacuum leaks.
          Originally posted by Gruelius
            Right now I am not too worried about the idling issue coz it happens once in 15 times.
            What other things should I replace?
              Fuel filter.
              Pull the valve cover off and post some pics of the cam gears. They're usually a good indicator of the condition of your timing components.
                Basics
                plugs may be ok, clean them and set gap (but i run ngk and check often)+antisieze
                maybe even
                cap/rotor
                wires
                air filter
                fuel filter
                tran/ diff fluids
                brake fluids
                coolant (bmw blue only here)
                oil/ filter (no fram)
                rotate tires
                than
                check for cracked hoses, intake rubber
                clean up the AFM and throttle body (usually has resin if valve guides are worn)
                maybe some injector cleaner before the oil change.
                check throttle cable, and throttle body.
                remove all excess weight. and happy trails
                3 pedal club
                200,k+ club
                cabrio club
                port-matched- polished- purring www.BMWpark.org
                </div>
                linux since 1999
                  Originally posted by idanity View Post
                  Basics
                  maybe even
                  cap/rotor
                  isn't it a coilpack? (i'm still a noob)
                  My year in Germany
                  Feedback
                    oyeah.
                    maybe
                    i have a 89 m20, so i have the cap/rotor, it might not have that. so, if thats the case.
                    check individual coils, etc.
                    3 pedal club
                    200,k+ club
                    cabrio club
                    </div>
                    linux since 1999
                      yes, no cap and rotor on a 91 318
                      everything else that has been listed is good
                      Id service the icv valve , which can be causing your idle issue too
                      yes get rid of the crap under the intake manifold
                      run a tank or two of lucas injector cleaner, before changinf fuel filter
                      check your belts, keep a spare alternator belt
                      you listed rotors adn pads, order at least one new hub retaing screw, if not 2 ( cheap) and even maybe one brake pad sensor as these often break coming out ( unless you live near a bmw dealer shop who carries them) ther is a trick to shut the light off, if you break a sensor
                      I advise also that if you own a m42 and ordering parts, to order a new radiator bleed screw, cost a whole $2. worth haveing around, Ive seen newish ones break coming out , O rings drop off into the twilight zone never to be found, old ones that havent been bled in a while snap right off
                      even bought a m42 basket case that the p.o. had tried gluing on a broken bleed screw
                      dont forget to reset your servie light ( easy task) after oil change
