Slow starts
  • Jean
    • 18228
    Slow starts
    I think ever since I've had my car it never (rarely) started right away like the new cars do. It's quite annoying and I want it fixed. It did this with the m10 and doing the same thing with the m30. Starter cranks right away, battery / alt is good. Fuel injectors have been rebuilt, new fuel filter, new plugs, ignition components, tried multiple dmes...same thing.
    It takes about 1 second to start, and I want it to start right away.....
    I am thinking it's one of the two fuel pumps?
    The first things to do are to check the fuel rail pressure while cranking the engine after it has sat for a while and have a smoke test run on the intake to look for intake leaks. The rail pressure should be close to normal and come up to normal within a turn or so of the engine. A leaking check valve can cause pressure to bleed off when the car sits, but if the pumps are good the pressure should immediately reach normal.
    • Jean
      • 18228
      All the gaskets and hoses are new, but I did re-use the brake booster check valve. Would a failing FPR affect this?
      • Lunner
        • 222
        Just a noob shooting in the dark here but this sounds a lot like my starting problem, and the culprit was the flywheel.
        Have you had a chance to see the condition of your ring gear?
        87 325iC 90 325iC 88 325iC 87 325i 87 325iS 87 325eS
        • Jean
          • 18228
          Yeah, it's fine and starter is good as well. Fuel pump(s) are the only original components left to swap...
          • Wh33lhop
            • 11705
            Have you checked the CPS?
            paint sucks
            • Jean
              • 18228
              It ohms out ok.
              • Wh33lhop
                • 11705
                As I recall, that doesn't necessarily mean it's in perfect working condition. We just traced a no-start in my buddy's M20 to the CPS, it starts right up now as opposed to the long starts beforehand. $40 fix. :) Do you know someone with a B35 without the long start problem? Couldn't hurt swapping it out.
                paint sucks
                • Jean
                  • 18228
                  Might give it a shot since it's easier / quicker than a fuel pump swap for now...
                  • StereoInstaller1
                    GAS
                    • 22679
                    I swear, I am gonna install a permanent fuel pressure gauge on mine
                    Closing SOON!
                    Thanks for 10 years of fun!
