gearbox shifting problem 323i e30
  • tuliongolo
    • Sep 2004
    • 4
    Hello, my problem in my 323i follows: :(
    1. the first march does not enter well, she is average capricious enters the first opportunity suddenly and other times I must intertar it but of once. This happens as much with the car in cold as in hot and with the stopped car.
    2. The reverse march, I must too much push it towards the flank, to such point that already touches to the central console and the boot of the handle this all defeat.
    excuse me my tarzan english, but my mother language is castellano, :!:
    in castellano or spanish :arrow:
    Hola a todos, tengo el siguiente problema, a ver si me pueden ayudar a solucionarlo:
    1. la primera no entra bien, es media caprichosa de repente entra en la primera oportunidad y otras veces tengo que intertarlo mas de una vez. Esto ocurre con el auto tanto en frio como en caliente y con el auto parado.
    2. La marcha atras tengo que empujarla demasiado hacia el costado, a tal punto que toca la consola central y la bota de la palanca ya esta toda rota.
    alguna idea... :?: :?:
    thank you
  • kowalski
    • Jan 2005
    • 1791
    reverse your supposed to push hard so that you dont put it in first by accident when starting as for putting it in first. well if its really hard to do then your sincro mesh is gone in first gear if it does it in all the gears then its your clutch.
    • cthulu703
      • Oct 2004
      • 288
      I think it is probably your shift linkage. I am not sure if I understand your post though.
      • kowalski
        • Jan 2005
        • 1791
        yea neither do i...
        • tuliongolo
          • Sep 2004
          • 4
          driveshaft 323i e30
          well, finally the solution to the problem, is replace the piece number 16
          Thanks to ImageShack for Free Image Hosting
          Regards.
