I keep getting a low beam failure on my check control but no actual bulb out, any idea why or how to fix, thanks.
Low beam failure...
check your fuses and in the fuse box is your relay for your lights its the the farthest back and to the passenger side i believe or it is one up from that, its the odd one out of the rest of the relays, it should make a clicking noise when you switch to high beams then after you have the high beems on check the voltage to the high beam wire on the light, if low volts or no volts then replace the relay, and unless you'v done some do it yourself wiring or fidling no other wiring should be moved or damaged and the relay or fuse should fix your problem. im not sure if this post makes sence but it gets the idea across im falling asleep right now so it might not make a whole lot of sence.
