I am installing springs/struts. Question: How do you get the tie rod and control arm thin off. I know, I should search and use the Bentley, but I need this done right now. All help is appreciated.
Thanks.
Jim
Propane torch for heat, lots of PB blaster and a blunt object. Ideally, there's a special tool that you use an impact wrench with to crank the tie rod ends out, but it sounds like you're strapped for time.
