1988 325i.
bosch 173 and/or chipped 153.
On the way to school yesterday I was driving normally and the car started to act like it was dying... not running on all cylinders it felt like. It acted that way for a good 5 minutes, then went back to normal.
After school I drove a good 30 miles with the car running fine. On the way home from work it started having that problem again, but never went back to normal. Sounded like a Subaru, shook a good bit, and felt underpowered like it was running on 2-3 cylinders.
I "fixed" it(for now) with a valve adjustment??? would this be logical or no?
Things to note:
Coolant temp sensor is broken(I think this is my cold start issue?)
replaced AFM
checked the plugs, they get power.
smelled fuel on all spark plugs when I took them out.
I've searched and searched and found a good bit of similar problems, but none were "fixed" by a valve adjustment
Things to note:
replaced AFM
