Just finish replacing all the hoses underneath the intake, now trying to bleed the system but no coolant seems to bypass the radiator hoses (remains cold when I have heater on). I am under the assumption that the thermostat is stuck closed? I may have reverse the coolant temp sensors connected to the block but even then, coolant should flow correct?
Any help greatly appreciated, need the vehicle running asap.
